Can a FireWire hub be used on a VAIO? I want one with 2+ 6pin female sockets. The unit has a PSU, so would the VAIO be able to handle it?
Secondly whats the best way to clean this keyboard?
I don't see any reason why the i-link hub wouldn't work.
Keyboard cleaning: air duster, soft cloth, and loads of patience
Or turn it upside down and shake it, if it's full of munchies
Works for me :smileygrin:
You are brutal
Is this how you get your mothers to give birth
You are brutalOnly on the hardware Rob, I'm more gentle with the software
Is this how you get your mothers to give birthAnd there was me thinking you were au-fait with the female anatomy
the exit location works best when she is right way up, but giving her the odd shake does tend to hurry things along
, and Rob started it
)the exit location works best when she is right way up, but giving her the odd shake does tend to hurry things along![]()
Anyone who can get Rob to reassess the situation has my respect
As for Faith, I have to agree with Rob, that's brutalI see, all boys together
Hehe - well - you are being rough with the VAIO
