Hi all
I have a FE41S and the left click button appears to be stuck down a little. It still kind of works but doesn't click either when it's pressed and can sometimes register a double click when only press once.
Can the cover come off for inspection?? Has anyone else experienced this??
Many Thanks
Shaun
Hi Shaun,
These buttons are quite complex to replace - this job is better left to Sony.
The replacement buttons can be bought from Nexttronics - it is part 8 numbered 266480701 here: -
http://www.nexttronics.com/reference/sony/fe8/int-FE52B-H.htm
You will need to remove the palmrest to get at the touchpad parts. This is not shown in any detail in the manual but it looks a big job.
