Hi Community,
I own a sony vaio laptop, model no PCG-8Z2M.
Now over past few weeks my screen has been acting very strange with all colours and everything mixed up.
On device manager I noticed a nvidia garphics card GT 8400 installed. I uninstalled it and continued to use the standard VGA grahics... I could not find any trace of the Nvidia card on PC with a view to try and re install.. The other day the computer developed same fault as show on attached file..
I have read on forums that Sony had a particular issue with this model and graphics card and were recalling them.
Now I can;t find where I read this and my warranty has well expired. Does anyone out there have a solution or similar experience..
Trevor
Hello my friend...Forgive me if i make a mistake but i think that problem is from your graphic drivers...try reinstall them...if your system was xp pro i will know what exacly is...but on 7 not so much...:)
Hi Trevor,
You are quoting the chassis model. Have a look on the screen surround or in Vaio Control Panel
for the correct model reference.
I think you will find it is a VGN-AR51, if so this model is not covered by Sony for the out of warranty repair of faulty NVIDIA graphics chip.
Rich
