Hi can any one help please.
I have a 6 month old vaio and when I start up its telling me I have a failing hard drive, back up files and replace. Press F1.
There is no noise from the laptop but it just freezes up all the time. How do I check if it is the hard drive?
Or do I just go to Sony to get fixed? Is this a manufactoring problem?
Any advice most welcome.
You can try various diagnostics - have a look at the tutorial here: -
http://www.sevenforums.com/tutorials/433-disk-check.html
However, if your Vaio is within warranty, I would send it to Sony to have a new drive installed.
Thanks I will try your suggestions, but will probably send back to Sony as ony 6 months old so still in warrant.
Thanks again.
