3tonemesh
Explorer
f15a 1s2es
Hi Guys
             Does anyone know if it is possible to turn off the keyboard light?
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.GB.title
Thalamus.
Champion
Hi 3tonemesh,
welcome to the Sony User Community Forum..:smileyhappy:
try this..
Open Control Panel.. (with windows 8 it may be easier to search your apps for Vaio Control Center)
The open Vaio Control Center..
You should then see Keyboard & Mouse..
Expand the tree & and you should find be a few options to change your keyboard backlight settings..
5 REPLIES 5
Thalamus.
Champion
Hi 3tonemesh,
try this..
3tonemesh
Explorer
Hi Thalamus
                   Thanks for the solution,and your time.
Thalamus.
Champion
You're welcome 3tonemesh..
zeeshanaayan07
Explorer
Thanks for sharing a great post
Tags (1)
Thalamus.
Champion
Glad you liked the post & welcome to the Sony User Community Forum zeehanaayan07..:smileyhappy:
