Hi
I'm getting an error. The DVD isn't working. I vaguely remember turning the power off on it to save battery some time ago. Can't remember where it was I set it though!
However. now I need to use it. I went into Device manager, and it says the DVD is disabled; I go onto properties, and it gives this message
Error with DVD (This device is disabled. (Code 22))
I click on the 'enable' button and a dialog pops up saying it can't be enabled.
Is there a problem with the DVD, or where do I turn it back on?
Johnny
Hi Johnny,
Try uninstalling the device in Device Manager (right click and select uninstall) – and then re-boot. The drive should be detected and reinstalled.
If this fails to resolve the problem then try booting in safe mode to rule out any driver/software conflicts.
