So here's my problem.
I have a Vaio VGN-FE31B and I've been having some weird problems with my dvd-rom.
Some DVD load in 5 seconds, others just keep spinning there forever with weird noises coming from the drive.
Also, I have this pack of 50 LG dvd's, I burn the DVD with Nero, data verification works, and the DVD loads normally, but when I eject the DVD and put it again, it does not load at all.
So I'm guessing this could be a driver problem of some sort?
I've been searching the Internet for a month now, and no solution was available, so please I beg you, I need your help.
Hi HassanE,
The problem you describe is rarely driver related.
The usual cause is often a failing drive, a dirty laser lens (especially if this is happening with pre-recorded DVD’s), a dirty media surface, or the brand of media. I would first try cleaning the lens with a proprietary product and if that doesn’t resolve the problem then try a different brand of media.
In order to eliminate a driver problem you could of course remove the device in Device Manager and then re-boot.
Hi HassanE,
Would a firmware update cause this in any way?
Most unlikely. Notebook drives can be very fussy on brand of media and I suspect that this is the problem.
Try Verbatim, or Sony media...
