Hi I have fs 215s laptop which came with XP home. I have changed to XP pro and now I cannot install some of the drivers. downloaded the full packige for 215 from vaio ,steel the same.can any one help????
Here is a good link here that shows the correct installation. Maybe you can recover and start again
Which drivers are you having problems with evelin1?
hi Rich. I am having problem with nvidia, modem drivers
Hi Tony. thanks fo the advise, but it dont help.the XP on my laptop crashed and I had to install a new one.
