My VGN-FS415S
can`t found the PCI-Device driver...
i think it s something with the audio,cause it don`t work...
i have downloaded all drivers but it don`t work...
can someone help me...
if i want to open the sound regulator it says install a mixer at the hardware ...
please help i want to hear some musik :)))
Welcome to the forum,
Go to vaio Link and download the latest drivers for your model and install them especially the audio drivers. If that fails go to the device manager and see if you have an exclamation mark next to the multimedia device. If so delete the driver and reboot and XP will reinstall the correct driver
Hi mate
I found the drivers that you need to download.
http://www.vaio-link.com/downloads/select/select.asp?l=en&category=-1&serie=-1&m=2156
1) Open the link
2) Scroll down to the driver's tab and download the file
3) Extract the file and open it
4) Click Start then Right Click My Computer
then Click Manage
5) Then click on the Device Manager tab then scroll
down to Other Devices
6) Then double click the your PCI-Device (audio card) then click
the Driver tab then click Update Driver
7) IF using service pack 2 select No, Not this time when asked to update the through the internet.
😎 Choose Install from a list or specific location (Advanced)
9) Then select Search for best drivers in these locations
10) Finaly open the location where you stored the drivers that
you downloaded from VAIO-LINK then it should be
searching for a driver.
11) Once completed BOBS YA UNCILS BEST FRIENDS
SISTER
From Dean
If you have anymore probleams do not hesitate to email me at
[email protected]
Or if you would like you can contact vaio-link customer support at
From the UK (0.07 GBP/min*)0870 240 2408:smileyhappy:
i allready do this but XP can't find the correct driver...
Hi mate
1) Open the link
then Click Manage
SISTER
From Dean
[email protected]
Email Dean/Amir :smileygrin:
Btw William dont infact never call me mate, I really dont like you, I think you are just some old looser who spends half his time trying to find a way to get into and arguement with me and if you dont get it your way, you go and ask some other user to go and argue at me, goodness sake william im only 15 and im acting more mature then you.
You are some 40-50 yr old man 4 christ sake, act your age.
From Dean
Don't ever ever ever called me ...DUDE:smileylaugh:
DEENNNN it works THANKSSS
