I need a video driver(NVidia GeForce 8400GT CPU) for Sony Vaio VGN-FZ11E (for Windows 7). Can anyone help me?
Thank you!
Hi CozmaAlexandru and welcome.
Sony have not provided a nVidia driver update for Windows 7 your model.
You can try Google for a solution but as a last resort you may need to modify the driver installer .inf file to allow a standard nVidia unified driver to install.
Go here and read the "Quickstart Guide" to this process at the bottom of the right-hand column: -
http://www.laptopvideo2go.com/drivers
Hi
Thanks for the reply, I cant find drivers on the site you provided. I have ordered a recovery cd, will that solve the issue? also i get a fuzzy screen but when i lift my laptop up or change it position it goes away, is this due to a loose wire? the thick blue lines however remain always
