Just yesterday i installed the latest update of dolby home theater by my driverscanner. Since then, every time i open my windows the following message shows up: " The current dolby audio driver version is 7.2.8000.13 and the software application expects driver version 7.2.7000.6. please install a valid driver and software application combination". I have no audio on my .mp3 .avi .mkv. etc files, yet the sound works perfectly on my videogames and on my browsers like youtube etc.
I 've searched the internet for the specific driver or a thread with related issue but i can't seem to find any.
If anyone could help with this problem i 'd really appreciate it, thanks.
Welcome.
It looks like the driver version must match the installed software application.
I suggest you roll back the driver to Version 7.2.7000.6 to match the Sony installed
Dolby® Home Theater® v4 application.
http://www.dolby.com/gb/en/consumer/technology/pc/dolby-home-theater-v4.html
Personally, I would not blindly follow recomendations from these driverscanner websites. They can be dangerous as drivers are often modified by Laptop manufacturers to best match their hardware.
Welcome.
mi laptop tiene problemas de audio. se escucha chilloso y me sale un mensaje que el controlador de audio dolby correspondiente es 7.2.7000.6. lo que pasa es que actualice mi laptop a windows 10 despues que la actualice el audio quedo asi y no se como solucionar este problema
