The topic is my question. I cannot find the info anywhere. If the sd slot in my vaio does not read a sdhc card of a camera, is there any way to make it work?
Thank you
Hi marpyry,
According to pages 57-59 of the manual your model it will read SDHC.
“SD memory cards with capacity of up to 2 GB and SDHC memory cards with capacity of up to 32 GB have been tested and found compatible with your computer.”
ftp://ftp.vaio-link.com/pub/manuals/Notebooks/VPCE/VPCE_H_EN.pdf
Rich
Hi marpyry,
Rich
Thank you very much! This was a helpful information!
You’re welcome marpyry.
