Can it support ? Memory stick duo (shorter size) and there are two different model, fast and normal. Does it both support or not? Do I need to use adapter?
Think you need the adapter.
Yes, you need a adapter for MemoryStickDuo /-Pro. If you buy a MemoryStickDuoPro from Sony, then there is a adapter in the package.
Seb
I have seen some which don't have the adapter, so do check before purchasing.
Uups, my failure. Forget my Post.
I get my adapter with my Cybershot.:smileyblush:
I'm not sure, but in the SonyStyleShop you must pay approx 7-9¿:smileyconfused: for the adapter.
No worries.
I have an adapter somewhere so i just use that and save
