I hav updated all the components for my vaio pocket and after that, it is not recognised by sonic stage or the vaio music transfer. When i connect it the (remove disk F) file is recognised but not when i go into sonic stage or the music tranfer its not, it just says
"Device not Found, please connect a target device".
Can anyone plz help. I think it could be down to some changes when i updated it but i am not the brightest with computers and don't know wots wrong. So could some help ..please.
Help someone!!
Hi Robby 41
I Have the same problem and the solution is go to the Settings/Initializations/HDD Format...and after this Sonicstage recognize Vaio Pocket...
So you have to transfer all the musics again...
Just another problem of Sonicstage...
So..whith me works,i hope that this Work´s whith you
Nope, has nt worked thanks tho. but my vaio is still not getting recognised cud sum1 plz help. Is there anything else i could do?
sounds like you've got the same problem i had!! i eventually managed to sort it.
My post
The solution is at the end of the post.
