Hello All,
My 215b notebook appear to let the fan kick in as soon as I switch the machine on. Im not doing anything apart from browsing the internet. No downloads, nothing taxing.
Futhermore, the CPU usage seems excessively high (100% at times) when Im surfing.
Is this normal with these models? should I be worried?
Am I paranoid? (no need to answer that one guys) :smileygrin:
I would check for spyware etc. Try Ad-aware from http://www.lavasoftusa.com/support/download/ and Spybot S & D from http://www.safer-networking.org/en/spybotsd/
Are you connecting to the web wirelessly?
If so check www.vaio-link.com for an update.
Thank you - I will try to connect to that later on today and let you know how it goes
I'm afraid not.
Do you access the net wirelessly?
(Sorry I need to know this)
I'm afraid I don't. I have only have had this notebook 1 week so doubt if I have any adaware problems, but could you guys please point me towards some good but free spybot sites.
thanks.
The links are in my first post.
Hmmmmmm
Go to task manager (CTRL+ALT+DEL) and click on processes.
Click once on CPU usage and tell me which is using the most.
