Is it possible to connect my PCV-V1to my Sony TV using the TV as a monitor ?
I think the only way to do this is to buy some sort of TV-Out USB adapter. You can't do it on the stock PCV-V1.
if its like the pcv-w1 it may be a bit tricky..
the optical is 'OUT' so you can hook up to an external 5.1 kit but everything else seems to be 'IN' only.
as suggested i reckon the only way you will do it is by some sort of external adapter.....
As GK said I think there's no video-out.
