I raised a topic and now it is closed. How do I change the status to reflect this?
Hi johtaylo13,
you can't mark a tread as closed as such but there are two ways to mark your thread as answered,
1. When replying click the circle next to 'Yes my question has been answered now' this will mark the thread as answered.
or
2. If someone has supplied you with a solution that has solved your questions then simply click on 'Correct answer' at the bottom of their post and this will mark that post as best answer & also mark the thread as answered.
Hi johtaylo13,
or
