CD Drive making lots of noise
Pikeybobs
New
My CD drive has just started making a lot of noise when i insert a CD. It varies in volume for different CDs but it makes a sound like its off balance or scraping against something.
Any help would be greatly appreciated, thanks in advance.
Adam.
Tags (3)
2 REPLIES 2
levan.k
Explorer
Try to remove the CD Driver from the slot and insert it back, you u need to just unscrew couple of screws, see if that works. Otherwise, try to install driver again. Since when this problem started? and after what ?
Pikeybobs
New
I have only just bought the laptop and with the one CD I was using before there was no problem, I only noticed it after I started trying other CDs. I will try to remove the CD drive and reinsert it.
Having taken a closer look at it, it seems quite loosely attatched. Would this instability be a cause?
I don't want to void any warranties so i'll put off removing screws, parts and the like for now in case.
