About:
Hi Stormer-R34,
You have to be logged on as an administrator, or disable (temporary) the UAC (user account control). To do that, go to:
Control Panel > User Account and Family settings > Change Security Settings > unselect "Use User Account Control (UAC) to help protect your computer".
Reboot the computer and now you can update all you like.
Hi DJ_Arno,
Thanks for the help, but I figured out what the problem was.
Then I couldn't find this thread.
Problem created by:
- Sandboxie
Reason Why?
- Sandboxie has a feature called DropMyRights, with that activated my IE not running with Admin Privelages.
Solution:
Removed IE from Force Start with Sandboxie, then tried Vaio Update and it worked.
Problem Solved.
_
