Hi everyone
My question is quite simple does anyone know the exact CMOS battery requirements for model "sony vaio vpc-s137gx/b "
Thank you in advance.
Hello @WiseMoves,
all coin cell batteries of the same size have the same voltage. So if you can figure out which size it is, you know which one to replace it with.
I assume it is a 3V CR2032 battery.
- Nic
