I just bought this Vaio and I am not so familiar with it. In the description it says that the cam is on whenever I turn on the laptop. But I think it does not work. When I tried to initiate the cam on yahoo msgr it did not come on. Do i have to initiate something...even if I just want to see my cam working and get the screen without initiating the cam via the msgr service.
Ty for ur help
romanticpearlz
I use FE31H and it has a in-built cam.
If u have cam, you should can enable it manually by clicking on 'scanners and camera' under my computer.
Do u have an indicator beside the cam to indicate it is ON?
Hope this helps
Regards,
Giri
