Hi guys!
I have that problem since a while.
I cant install the Camera softweare on my FE41M. Strange, cos I have downloaded the latest soft, and any attempts to install that soft so far failed. The Installation window pops out on the screen but after fev seconds suddenly dissapearing, and the installation is not continuing. for Any solution I will be gratefull.
Grzesiek
Hi Grzesiek
To check if the VAIO Camera Capture Utility Update 2.2.03.11150 was successful browse to "C:\Program Files\Sony\VAIO Camera Capture Utility\Version.txt".
The version numbers in the Version.txt file should include "2.2.03.11150".
