Hi
Does anyone have the original BIOS for the VGN-A397XP ? That is version R0060F2/RK060F2? I believe all the european VGN-A series have this version. I scrwed up mine and I can't get it from sony support sites
Thanks!!
My notebook is Vgn-A617s but ı don't know how can ı help you?If you can explain a little bit more maybe ı can help you.
The only one I can find on Vaio-Link for download for the A-Series is R0080F1.
It may be worth a call to Vaio-Link.
Hi xtonie,
Have you tried contacting Vaio-Link they may send you a copy of your BIOS..
Edit: Evening Blencogo...
Just an afterthought xtonie ..............
You have tried resetting the BIOS to its Default Values?
Hi, Thanks everyone!
I did try a bios reset and contacted vaio link but no succes now.
Could someone maybe save the bios including the EC bios to a file?
Big thanks
Hi, what bios do you have (see System Information in Vaio Control Center);
Thanks!
Hi
I contacted vaio link and finally I got some answers, I must say responses are coming very slow and troublesome, but strange thing: they want me to bring the notebook in for repair just to restore bios.
What I did, I " upgraded" my bios to the US version (which can be downloaded!!) but since then my fans are on all the time! I think the problem lies in the updated EC BIOS part.
So please can anyone help me with the original BIOS R0060F2/RK060F2?
Or should I bring in the notebook?
BIG THANKS
