Is it possible to flash the bios without an internal floppy drive.
can it be done by cd drive or external floppy drive
i used the winflasher that sony packed with the bios update. see if it is also availabe for your bios type and version
joe
it has an application called phlash which is I think the wi ndows flasher but it reports the error 'emm386 or similar is running'
any idea how I can turn off this emm386.
I have been into the system settings via control panel and turned off the hard drive paging settings but that does not help
anyone any ideas
hi,
have you tried booting into the safety-mode and then run the win flash utitliy
joe
You could create a bootable CD and flash from that. All at your own risk of course
