Hi to everyone,
i have a VGN/S4M
i need to have a exit digital audio from my notebook and use the dolby digital at home.
dolby digital has also a ottical cable and i would to use this.
can i use the normal digital exit from the pc with some reductions?
the exit of notebook is analogical audio or digital audio?
which is the best choise?
thanks
If you have SPDIF use it
I had a look at the specs of your lappy, no audio out Im afraid analogue or digital, a docking station may give you an audio out but I doubt it will be digital.
£20 dvd player will do the trick
i have in the dolby not in the s4??? i not understand what u want to say
You need a creative 7.1 card if you want the best Dolby
