i have installed a second hard drive in my vaio but i think i need a caddy to secure it properly and stop it from freely moving about does anyone know where i can get one from? thank
thanks thalamus have you any idea where abouts i can find the part number on my vaio that i need?
Hi squashme
I can not find the AR51 series listed on the Nexttronics site, however I have found an exploded diagram for the AR31 series, HERE , which may help identify the HDD caddy (part 152 looks promising).
It may also be worth sending an email to Nexttronics to clarify if the part will fit your AR51 before you make the purchase..
