Alps Touch pad Web Assistant - GRT916V
johnddd
Visitor
I have set this function with visual feedback on. I see the back and previous buttons moving as I click - but IE does not actually respond.
Any solutions thanks.
6 REPLIES 6
profile.country.en_GB.title
robpaxton
Explorer
Make sure you have updated to the latest version from www.vaio-link.com
johnddd
Visitor
Yes I looked there but could not see any relevant files.
Thanks
robpaxton
Explorer
I am using version 5.3.510.9 and it works fine. I know there were some problems with previous versions.
johnddd
Visitor
Hi Rob, my driver is 5.3510.5 which is earlier than yours so you are probably right. Where will I find your later version do you think?
I
Regards John
robpaxton
Explorer
johnddd
Visitor
Thank you so much .. all fixed!
