I have tried to connect my Sony camcorder to my A115Z with a 4pin to 4 pin i-link / firewire cable. The computer cannot locate or connect with the camcorder. I have tried all of the help suggestions given by XP. I will try the cable on another machine, but am I missing something simple here? The same camcorder worked fine on my old desktop with a 6 pin to 4 pin cable.
Did Sony suggest to get DVGate 2.1?
If they did I would ask them to give you a direct link, as none of us have ever seen it for download.
I just want to push this back up the forum list to see if anyone has anymore input on this - PLEASE!
Hi there. I think you may be looking in the wrong direction. I don't know the version of DVGate on the A115Z, but it's definately are then 2.1, so my belief is that whatever patches were released for previous versions are integrated. I looked and saw that on the download section of www.vaio-link.com, if you go into Patch/Upgrade and then OS, there is a QFE and a Hotfix related to firewire devices. No guarantee it'll work, but definately worth a try if you aks me.
Gnomo74
