Hi everyone;
I have a dead Vaio on my hand and now that I am using my PC, I get system shut down everytime!
When I switch the machine on, I get a message to close all the files within 60 seconds!
These words are also in the message: "NT Authority System through (RPC) Remote Precedure Caller"
At first I thought there is a Virus somewhere, but when I scan it, there is no virus.!
Does anyone knows why this is happening and how to prevent it?
Sabi
Fraid you got a nasty virus. There's more information and stuff about it here
Good luck
http://www.faqs.org/rfcs/rfc1831.html
I think that you have the Blaster Virus despitre what a virus scan says.
It would certainly worth trying a removal tool and installing the Microsoft update/hotfix.
If you are sure you haven't got a virus and your Windows is bang up to date then I don't know?
Assuming you have got the Virus your anti virus software must be well out of date.
I would suggest that after getting rid of the virus you immediately update your virus software and all available windows updates.
also if your running XP, make sure ur firewall is on,
Or better get ZoneAlarm
