INTENTO ACTUALIZAR LA BIOS Y ME DICE QUE NO ES COMPATIBLE CON MI VPCEB3C5E CUANDO LLEVO CASI 3 AÑOS USANDOLO , EN EL SOPORTE DE WINDOWS ME HAN DICHO QUE MI LAPTOP ESTA BIEN Y QUE ES SONY EL RESPONSABLE DE DAR SOPORTE A WINDOWS PARA QUE FUNCIONE .
¡Resuelto! Ir a solución.
According to the downloads page, there are no BIOS updates available for this model, can you tell us what program you're referring to?
I just checked the Spain website for drivers since the first link I shared was the UK one, still couldn't find a BIOS update or driver unfortunately.
Hi Jordi947,
Are you able to post this in English? You can always use Google Translate.
Cheers,
Pascale
Hi Pascale, really thanks for answering
I TRY TO UPDATE THE BIOS AND IT TELLS ME THAT IT IS NOT COMPATIBLE WITH MY VPCEB3C5E WHEN I HAVE BEEN USING IT FOR ALMOST 3 YEARS, IN THE WINDOWS SUPPORT THEY HAVE TOLD ME THAT MY LAPTOP IS OK AND THAT IT IS SONY RESPONSIBLE FOR SUPPORTING WINDOWS TO MAKE IT WORK.
a cordial greeting,Jordi947
You can find all compatible drivers for your Vaio on the downloads page here: https://www.sony.co.uk/electronics/support/laptop-pc-vpc-series/vpceb3c5e/downloads
Thanks for answering, I was afraid that there would be no update for my model. and now what can I do if windows 7 stops working? throw away my pc ???
and the program I was referring to is: VAIO BIOS Update Tool 1.2.0.04300 .i was dowloading from this link:https://www.sony-latin.com/es/electronics/support/downloads/W0010968#about.
a cordial grettings
The issue might be that the tool is from the Sony-Latin website and not the Sony UK one.
Yes ,i know that. I was writing from Sony.es, from Spain not from UK
