Hello
When will be possible to buy X95J 164 CM / 65 "X MOTION CLARITY, TITANIUM SILVER SEAMLESS EDGE, TITANIUM BLACK METAL EDGE STAND in Denmark ???
If you need info about availability, it's probably best to reach out to your local Sony support team in Denmark (or better yet, the partner stores you have there since they'd have more direct access to stock info).
Hope this helps!
- JD
