Hi
Is it possible to connect a wireless keyboard to this Television. If yes how do I do it.
Thank you
Tony M
No, but you can use the media remote app on your smartfone if you have one or a program called Remote keyboard lite on your pc.
Thank you for your suggestion. I will download the App to my Tablet and give it a go,
