First, sorry, I just bought a new TV (W8 range) and have a couple of questions ... it's not flooding!
Prior to my W8 SONY TV, I had a SHARP TV with an external dual-tuner SAMSUNG Freesat box.
I'm still using 1 tuner of my Samsung Freesat box, as well as the built-in satelite tuner of the SONY TV.
Now, if I press the 'guide' button, and compare to the same 'guide' as on my Freesat box, there are LOTS of information missing on my SONY TV.
Any idea why? Is anyone experiencing the same issue? And is there any workaround?
Thank you
Hi there
Thought Id answer a couple of your questions quickly before having an afternoon nap
Have a read through the following thread:
All your questions about EPG and Freesat should be in their.
Hi there
