Hi there
Can you try disabling the "HDMI-CEC" functions on the Sky box, and test out (might be called "Control for HDMI")
Have a read of the following thread:
http://community.sony.co.uk/t5/televisions/kdl-46w905a-home-button-not-responding/td-p/1769313
Hi there
Can you please describe how things are connected up - as this may assist, using what cables. Also which remote control are you using.
In regards to the bluetooth question - only bluetooth mice are supported (for web browsing), therefore no other bluetooth devices will work.
