Unfortuantley I cannot help you on this. Up to recently there was no conversion kit, and have not seen one in real life (if that is what they sent you anyhow)
Your best bet is to contact Vogels or Sony : HERE
I hope you get it sorted anyhow.
Hi there
Unfortunately this floor stand, as well as others are incompatible. This is because this model TV does not conform to the VESA standard. You will need to use the mount that Sony provided in the box, and add onto a cabinet/bench
For more information see : HERE
