After a couple of weeks use, my Bravia TV does not recognize USB drives anymore, not even USB cameras, it acts as though the USB port is not responding at all, nothing works.
The tv is just about a couple of weeks old.
failure of any sort after a couple of weeks warrants direct replacement, get on to your dealer and explain whats happened and tell him you want a replacement set.
i should add, check that there is not a firmware update that may correct the problem, its worth a look.
Message was edited by: Bravia55HX923
