Many of the current crop of TV's can have the firmware updated directly from the device within the settings option and may even prompt you when there is a new one available. However if its not updating, you want to do it manually or have an older TV, below are some resources and pointers which should be helpful and will ensure you update the product correctly.
Its worth noting that updating the firmware *if* done incorrectly can cause issues with the TV, so whilst updating is a worthwhile exercise as updates improve performance and fix bugs, please follow the instructions listed on your products support page carefully when carrying out the process.
Do post below if you have any further questions and someone will be able to assist.
cao imam problem oko preuzimanja firmvera za sony bravia kdl-32e302
