i have a 2 yr oldbravia kdl40cx520 tv without the table top stand , i now need one of these and wondered which other model numbers pedestal stands will fit mine as i understand some are not interchangeable ,
Hi there
The following website has want you want. However the price IMHO is high.
Edited by Drew - Link removed.
in addition to above Sony recommend here too,
Hi Bravia - I knew you had another website, just couldnt think of it. However, both mine and your links are from the same company. From a Whois lookup on domain name. Fancy that hey !
