SONY BRAVIA KDL32CX523 - When watching the TV, if you switch it off then back on again there is no picture although there is sound. If you leave it for a few hours then switch it back on again then the picture comes back on. Can anyone advise what this 'fault' may be and how i can fix it. As you can imagine this is very frustrating as i have to listen to a blank lit screen.
Thanks
Hi there
My advice is to contact an authorised Sony repair centre and have this fault looked at. It appears that this is a hardware fault, and there is very little forum members can do to assist.
Cheers.
Thanks! This I will do, just wondered if anyone had experienced the same problem.
