- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Any idea if this TV can be wall mounted using a swival arm bracket?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Don't know if this helps, but I've just been pointed off the this link, where it appears a conversion kit is now available. Brackets are pricey, but I'm trying to find out if the conversion kit is available separately.
http://www.av4home.co.uk/blog/guides/wall-mounting-a-new-sony-kdl-w6-series-tv/
Must say thanks to Quinnicus for digging out this bit of information.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Seems KDL42W653A does not take a standard VESA fitting and for the sake of having four screw hole fittings in the right place it seems we cannot take a Sony TV and must look elsewhere. Very frustrating and quite a big design flaw.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It's the same issue with the smaller 32 inch model. Really disappointed. Our TV is in an alcove and that's why we need a swivel extending bracket.
Lovely telly though...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
