I have a Sony KDL-46z4100 that won't show a red stand-by light at all. TV will power on with a green light, but only with vertical lines, no sound and no ability to change the input or channels. I've purchased a few pre-owned boards, main boards, t-con boards and power supply boards off Ebay with no luck getting a standby light or the lines off the screen. Any help or suggestions to resolve this would be greatly appreciated. Thanks
Hi @mlccc2, welcome to the Community.
The vertical lines sound like a problem with the panel, although this may have no bearing on the standby light issue. Have you ruled that out?
Regards,
Mick
Hi Mick-
Thanks for the reply. Yes I did rule out the panel. I acquired this TV from my neighbor whom I still have contact with that claims he turned it off one night and when he went for it again, it had just vertical lines on it.
Hi Mlccc2,
I found an article on the Sony website addressing this : https://www.sony.co.uk/electronics/support/articles/00091660
I'd recommend following the steps in it to resolve the issue
Cheers,
Rose
