I have a sony kdl 40w605b tv , first time when I switch to Discovery function I have a preview to all the tv digital channel , now is only a pictogram like a medall for sport, a notbook for news, do you know how to switch back to channel preview? It any settings for that?
Hi there
I have had a look at the manual for there, cannot find anywhere that specifically states how to exit it (the imanual is just never comprehensive enough). However try pressing the [Options] button on the remote and see if there is an exit or whatever. If not, try simply unplugging the tv from the power socket for 2 mins (you never know).
I "ve power off the tv , even I reset to factory settings , in The options menu is nothing to hide or show the preview , only to hide or show the catgory (e.g. Digital , Analog, CAM ,Youtube). For exemple in the Youtube category or Football category the preview are shown but in the Digtial iti isn" t , only the pictogram with the generic of the bodcasting tv .
this image is from Digital ( a piano is shown becouse is a music channel)
and this is from Footbal (with preview)
i put the pictures again
the digital http://postimg.org/image/e9d1xam27/
Football http://postimg.org/image/hubrzyr87/
Hey,
Are you pressing up and down on the remote? It scrolls you through different options and services. I can see from your pictures that the football stuff is 7th down the list (see the small dots on the right of the banner) and the channel previews are 2nd in the list. Hope this helps.
yes i scrolled upn and down , they are 7 pages but not eith options , thae page are from the input : th 1st is from the search mode , 2nd for digital,3rd for analog, 4th radio,5th youtube, 6th usb,7th footbal
i really don" t know what happend , maybe this preview are send by the cable provider(less possible)
Hi there
I have had a bit of a look into this, but unfortunately I dont have access to a 2014 tv to 'play' with. So I really dont know how to help or assist you on this one.
Unless another forum member can help, my advice is to contact Sony Support : HERE
10x for your support Quinnicus, i send an email to sony , i will let this thread open maybe someone give a solution
No problems
If you do find a solution, please post back, as it might help others and im curious too.
unfortunately no , the answer did" t provide any help
this is the answer from sony
" Dear Mr Adrian
Thank you for contacting Sony regarding your KDL-40W605B, we appreciate your enquiry about how to change the Discover options.
In regards to your enquiry, please note that you may change the Discover settings using the Options button as explained on the following link:
http://pdf.crse.com/manuals/14HM154111/EN/hotpicks.html
I hope that this information has been helpful. Should you have any further questions, please feel free to reply to this email.
Thank you for your enquiry."
But I was cheking the option menu before there is no option for preview. 😞
