Can anyone tell me what part number should I seach for my SONY KDL 40V2000 Screen as a part ?
Is that screen model compatible with other sony models ?
Regards,
1-802-184-11 LCD PANEL (40INCH FHD TFT) (KDL-40W2000)
Manolo
Monolo thank you for you quick response.
It was my mistake.... the correct model is KDL 40V2000 and NOT W2000.
So, the question still remains open .......
Thank you,
1-802-267-11 LCD PANEL (40INCH WXGA+TFT) (KDL-40V2000)
Manolo
Manolo,
Thank you for your info but I didn't find any display replacement parts to SONY. Do you know if there are also compatible panels from other SONY models ?
Regards,
Yes, example: KDL-40S2510/S2530 but the problem is the Panel, now this isn't on web and if is "available" (on the page but not for sale) it has a very high price.
Manolo
