Has anyone had any success using the recent Sony Channel Editor tool?
When I try the following instruction I have no list to re-order!
Modifying the channel list on your computer:
Hi @Jonnie1266
I noticed your post on the other thread, which might be the best place to post your updates and further questions. It keeps your question in context and if you 'bump' it to the top of the list it will likely attract more responses.
The tool does seem to be challenging a number of people, so hopefully a solution will be found soon.
Mick
