I've got a 32" Sony Bravia TV KDL32EX301 when I turn the TV on it comes up with the Sony logo then turns straight back off again. A red light starts flashing it flashes 6 times. I have tried to do a factory reset and tried to enter the service menu with none of them seeming to work maybe i'm doing it wrong any help would be great. |
Hi Sonytv1984,
welcome to the Sony User Community Forum..:smileyhappy:
If the stanby light is flashing red then this indicates that the TV's self diagnosis mode has been activated, I suggest you contact your local authorised Sony service centre and inform the them of the sequence that the Standby light flashes. Use the following link to find your nearest: Authorised Sony service centre
Hi Sonytv1984,
Thanks I will do just hope it's not going to cost that much to repair.
