- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony Bravia TV EPG "no event information" on freesat
Hi guys
Been trying to contact Sony via their web email support. the page endlessly loops on trying to send, no matter on what broswer i use. 😕 so here i am...
anyway
I have a Sony bravia TV KDL-42W805A.
I have recently cancelled my Sky package. so have been using the builtin freeview (aerial) for TV, which is all working fine.
However, i have decided to remove the freeview aerial and use the built in freesat tuner with existing Sky dish.
I can get over 800 channels with freesat. and the signal quality/strength is at the max. no issues there.
The issue im having is:
the EPG does not populate with information. all i get is "no event information". it will only appear once i view a channel. but im not flickering through 800 channels just to get the information to load
Because this don't load, it make the EPG completely useless
What am i doing wrong?
PS. the TV is not connected to the internet (yet) but has latest firmware update i think.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I too have got rid of my Skybox and using the sat dish and connection direct into my Sony Bravia. The way I use the TV guide now is to have an internet connection and select 'Guide' on remote, press 'Options', then scroll up to 'Launch Guide and Search'. Once this is selected a full program guide is displayed, it will give you all details of each program, cast/crew, related programmes and videos, option to record etc. This is powered through Gracenote and makes it a fully interactive EPG.
Hope this helps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
No need to contact Sony Support on this - Ill try and answer this the best I can.
What you are experiencing is completely normal and cannot be resolved. None of Sony's TVs are Freesat, only Freeview. The names "Freeview" and "Freesat" are given because they are the brandings for the EPG. Sony provides that satellite connection on the TV in the UK mainly because on the EU continent. As there is no Freesat EPG, the channels are not in a logical order with no EPG. You will get a "Now" and "Next" though when you individually click on that channel.
This of the Sattellite connection as an added bonus (as a backup), but other than that, you have to either connect an aerial to DTT services or connect your skybox to the TV as you can still use the skybox for freesat TV (you just cannot record or access recordings + PayTV services)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
So it doesn't auto populate the EPG over sat?
i feel like ive been miss sold...
or do i need to connect up the internet and freeview aerial to allow it to do this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Freesat is the branding behind the satellite EPG. This TV and all of Sony's TVs are not Freesat - They are Freeview. Therefore there is no proper EPG for satellite connections. The EPG is for Freeview only.
Can I ask you a question though? Were you sold this TV specifically for "Freesat" ?
You will only need the internet and the "Freeview" aerial cable for the IPTV Channels in the 225 range on Freeview. Connecting the internet to the TV, will allow you to have iPlayer, and YouTube and various other applications - which does expland on what the TV offers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
can't remember the sales pitch, but we brought it because it had both aerial and sat tuners. and the smart content apps like netflix.
if i knew the EPG didn't work right on satellite i might of looked for a freesat and freeview tuner.
seriously tho. how hard is it for sony to add a feature to the firmware to query the (now and next) listing on every channel? instead of me flicking through to get it to populate. or a way for the tv to get the listings via internet...
only reason the tv is not connected to the net at the moment, is ive been waiting for my new fibre connection to activate.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
I have had a little dig around and the only manufacturer that offers Freeview and Freesat built into the TV are from Panasonic. If you believe you have been miss-sold, I would strongly advise you speaking to the retailer you purchased it from. After all, you are the one that needs to be happy with the product.
However, If you like the TV, you could always add an additonal Freesat Box to the TV instead. More information is available on the Freesat website : www.freesat.co.uk
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hope this helps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Many thanks for this information - it is the icing on the cake for my new TV! I, too, was disappointed that it was not FreeSat, but this substitute seems to do the trick.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
