Can someone help?!
I bought a Sony Bravia KDL46W905 TV yesterday but cannot get it to link to the internet. It recognises my home wireless network and I am inputing the correct password for the wireless router, but it won't connect. The router is an Airport Extreme and it is set to WPA2 Personal.
Anyone any ideas?
Richard
The device you are trying to connect to is only a router which allows you to connect to the LAN but not necessarily to the internet , you will need to connect a DSL modem to the airport or get a combined router/modem and then it should work.
