x
Sony Bravia KDL-32W650A YouTube not working
profile.country.GB.title
yorgosntovas
Explorer
Hello, YouTube app in SEN does not working. All setting checked. All other apps working well. Any solution?
Thank you
Ýorgos
8 REPLIES 8
Wynyard65
New
Same here.  Error Screen quote:
"GOOGLE  400 That's an error.
Your client has issued an malformed or illegal request. That's all we know. "
I will try and contact Sony helpline.
Sandorx
New
It's the same for me with my BRAVIA KDL-48W605B  I hope it is just some glitsch that Sony can fix soon. I hope they are not pulling you tube like they did on some units from 2012.
Wynyard65
New
Just spoken with customer support. Tried a few things but no instant fix. They are looking into it further and will keep me updated by e-mail.
nevdot
Explorer
I have same problem with a KDL-40W705C , Youtube was working perfectly until the early hours this morning.
Now when I hit the app on SEN it freezes on the YouTube logo and will not progress any further.
yorgosntovas
Explorer
Hello all, it seems that SONY has fixed this problem, it should work now.
nevdot
Explorer
Yes yorgosntovas Youtube back to normal, As suggested by jjtee45 I did a factory reset (not too painful!) and then logged back in, problem solved, Thanks.
yorgosntovas
Explorer
YouTube SEN app is not working again!!! :rage:
