I have attached a community response from a Sony Agent who states that for registration purposes the KD-65XE7093 model should be registered as a model KD-65XE7003. I have no problem with this however, in particular does that mean the firmware intended for the KD-65XE7003 can also be applied manually to the KD-65XE7093 without any issues?
Hi there,
Thanks for posting. We'll check this and get back to you when we have more information.
Best wishes,
Ed
Hi TheMerlin486,
I guess this is true. Both TVs run on the same exact software which is Linux. Any software update released for the KD-65XE7003 will work with the KD-65XE7093.
Hope this helps.
Almou_10
