Anyone experienced seeing rather large block pixels when objects are moving across the screen - it doesn't always happen but seems to happen on HD channels sometimes?
For instance - I was watching Goldeneye on HD ITV and a couple of people moved across the screen and I saw these large block pixels behind them - never had a problem like this before and TV is only a few months old?
Is it reality creation or motion flow?
switch motion flow off, try it.
switch it back on, and you will see the large blocky pixels.
with motion flow off the picture is better.
it is a needless gimmicks are all the other distractions,
like reality creation, contrast enhancers etc,
with everything fancy sounding to off.
just concentrate on the basic picture options, brightness, contrast and colour.
I guess is the low quality of the broadcast. don't be fool by it saying HD... mostly is upscaled content
